06-19-2008 07:30 PM - edited 03-03-2019 10:25 PM
Hi Experts,
Anyway or any commands i can check with vlans are passing thru a trunk at the distribution switches?
cindy
Solved! Go to Solution.
06-19-2008 09:16 PM
Cindy,
You can try :
CatOS : show trunk
IOS : show interface trunk
above should provide you with vlans passing through a trunked interface.
Jorge
06-19-2008 09:16 PM
Cindy,
You can try :
CatOS : show trunk
Jorge
06-19-2008 11:22 PM
Jorge,
Cool.. :) .got it and have rated your post..
cindy
