MTRJ optic port on a cat2940 trouble
Hello !
I have a Catalyst 2940-8TF switch with MTRJ optical port and I cannot get the optical link up. It wouldn't establish a link with
multi-mode optical bridge converter, and it also wouldn't go up if i connect its own tx to its own rx. I have tried different optic
patch cables, changing port speed and duplex, changing IOS software - nothing helps.
Is there any other way to solve this?
owillins Thu, 06/26/2008 - 06:23
If you can find MTRJ-SC and SC-LC cables, then you can use a SC-SC coupler to connect them.
purohit_810 Thu, 06/26/2008 - 07:07
Did you try to give power manually on port?
Command: enable power
Dharmesh Purohit
rskrzek Thu, 06/26/2008 - 22:18
1. Your multi-mode optical bridge converter is 100 or 1000 Mbps ? mtrj is 100 Mbps only
2. SFP slot is empty? mtrj working only if it is.
