static mac-address
Jun 20th, 2008
static mac-address x.x.x.x vlan xx interface f0/0 interface f0/1
if this packet come to switch, switch will send out two interface or load-share on each interface
Pravin Phadte Fri, 06/20/2008 - 03:45
For interface-id, specify the interface to which the received packet is forwarded. Valid interfaces include physical ports and port channels. For interface-id, specify the interface to which the received packet is forwarded. Valid interfaces include physical ports or port channels. For static multicast addresses, you can enter multiple interface IDs. For static unicast addresses, you can enter only one interface at a time, but you can enter the command multiple times with the same MAC address and VLAN ID.
Pravin
