X6704-10GE / DFC3CXL
Answered Question
Jun 20th, 2008
Can I use a DFC3CXL on an X6704-10GE ?
Would the DFC3CXL work with Sup720-3BXL/PFC3BXL ?
Where can I find such information ?
Thank you
Correct Answer by n.nandrekar about 8 years 7 months ago
yes!
You can use it but the higher version will be downgraded to the lower version while working.Also if the sup is of the lower version DFC/PFC, you will have to insert the higher version DFC LC at bootup... inserting it later wont work as the SUP wouldnot be able to downgrade itserlf
For details on this please refer :
http://www.cisco.com/en/US/products/hw/switches/ps708/products_qanda_item09186a00809a7673.shtml
Hope this is helpful.
Niranjan.
(pls rate the post if it helps.)
Overall Rating: 5 (1 ratings)
Correct Answer
n.nandrekar Fri, 06/20/2008 - 04:32
yes!
Niranjan.
