Backup and restore system error CCM
Jun 20th, 2008
The following error is reported in the backup and restore log
09:00:12 PM] Dumping CDR database on xxx
[09:01:24 PM] Database backup verified.
[09:01:24 PM] Staging database dump from xxx to staging directory.
[09:01:24 PM] Truncating transaction logs for CDR database on xxx.
[09:01:25 PM] No CDR file exists.
no CDR file exiests??
never came across this before. The backup completes 100% but with errors. can anyone shed any light?
cheers
Overall Rating: 2 (1 ratings)
rob.huffman Fri, 06/20/2008 - 04:45
Hi Steven,
This error is due to the fact that you have configured BARS to backup the CDR Database but no files existed during this particular run. This is informational only and more of a "heads up" to check your CDR Service. If you are collecting CDR's on a regular basis check things like CDR Insert to make sure things are running.
Hope this helps!
Rob
bernards Fri, 06/20/2008 - 04:49
Thanks for the resopnse. The CDR insert is running. this has been checked. at a loose end!!
cheers
steven
Jaime Valencia Sat, 06/21/2008 - 14:51
on which server are you doing the backup? PUB or SUB?
You can have the CDR insert running but if you do not enable the CDR flag there won't be records, have you checked that indeed you have records under the CDR tables?
also which version we talking about?
javalenc
if this helps, please rate
bernards Mon, 06/23/2008 - 02:42
thanks for the response
cdr is running on the PUB
cdr flag is enabled
i have records under the cdr tables
version 4.1
could it be a possibility the cdr table is full. ie 1.5million record is the limit
cheers
Jaime Valencia Mon, 06/23/2008 - 18:02
you could find that out by doing a select count(*) from TABLE_NAME (sorry, i'm tired and can't remember the name of the table =) )
do that on CDR and TBL_BILLING_DATA from ART, there should be 1.5M as max in CDR and 2M under ART
javalenc
