Dynamic skillsets
c-bednarek
IPCC v4.0.4
Is there a way for a contact cneter supervisor to change the skillsets and or competence level of an agent without giving them access to CRS Admin?
Chris
Sure, glad it works for you.
Please remember to rate useful posts!
Chris
7 Replies 7
Chris Deren
Yes, this feature is available in IPCC 5.0.
HTH, Please rate all helpful posts!
Chris
Thanks for the quick reply.
we do have v5.0 running in a lab, where or how is that performed?
Chris
Define a user as supervisor and then login with his credentials to appadmin page, you'll notice that the RmCm subsystem is available.
Chris
I tried that, and all i get are system>logout and tools>plugins/RTR
Am i missing something
Did you ensure that the user has Supervisor role under tools --> user management. After the user is defined with supervisor role once you login to appadmin you'll see subsystem tab with rmcm under it.
Chris
I did. Duh, me... I guess it would have helped if i looked at the menu on the left hand side :-)
Thanks for the feedback, Chris.
Chris
