06-20-2008 05:31 AM - edited 03-15-2019 11:25 AM
Hi all. Ive got a 2801 CCME with an E1 card. I can call out successfully, however, as soon as we try to call in I get a dead tone (unallocated number)
Here is how i've got things set up (same rules work on my UC520)
voice translation-rule 1
rule 1 /494445/ /205/
voice translation-rule 2
rule 1 // /90/
voice translation-profile ADDZERO
translate calling 2
voice translation-profile INCOMINGDDI
translate calling 2
translate called 1
As you can see the number being called is 494445 and it should route to handset 205, but I just get a dead unalocated number tone.
Any ideas?
Solved! Go to Solution.
06-20-2008 05:34 AM
Hi, have you applied the translation profile under voice-port or trunk group ?
If yes and still no joy you have to look at the actual call with "debug isdn q931" and "term mon".
06-20-2008 05:34 AM
06-20-2008 05:43 AM
Hi mate, I have applied it yes:
voice-port 0/2/0:15
translation-profile incoming INCOMINGDDI
cptone GB
timeouts initial 5
timeouts interdigit 5
06-20-2008 05:46 AM
No I hadn't! i've got it in the notepad config but it must have errored when I pasted it into the terminal.
Thanks my friend!!!!!!
06-20-2008 05:47 AM
Take the suggested debug. Number can be different from what you think. Note you don't need any timeout settings under a PRI port.
