default directory handler
Answered Question
Jun 20th, 2008
All, how do I go about getting the default directory handler to have a list of names? I would like to have all names in the default, so that when a caller has the option of dialing by name, they can simply dial a few letters of the name and it recognize who they want. I have the cti route point poiting to the extenstion, which callforwardall to voicemail, which says "there are no names in the diretory"? How do I get the name in the directory?
Correct Answer by Jaime Valencia about 8 years 10 months ago
do all the subscribers have their recorded name? that's mandatory?
The handler is pointing to the whole list of subscribers or to a PDL?
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
jjoseph01 Fri, 06/20/2008 - 07:44
When I have it play all names, thats when it tells me "there are no names in the directory".
Correct Answer
Jaime Valencia Fri, 06/20/2008 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
jjoseph01 Fri, 06/20/2008 - 11:35
No recorded name. Let me try that and see what happens. They are pointed to the whole list. Will let you know.
jjoseph01 Fri, 06/20/2008 - 12:41
Thanks, the recorded name solved the issue. I appreciate the knowledge share.
