Link goes down
Jun 20th, 2008
I'm sorry if i set question in incorrect topic..
So - i have next problem:
I have next network:
INTERNET <---> Router <---> ASA 5520
And i have device of 3com - Tippingpoint 200E (IPS)
If i set tipping point between router and asa link on tippingpoint port to router goes up but link from tippingpoint to asa goes down...
I tried various option as:
- Set on tippingpoint & asa speed 100 duplex full
- set auto speed on tippingpoint & asa
but it's not working...
Please told to me some debug command which will help me in solving the problem
Richard Burts Fri, 06/20/2008 - 11:25
vadim
You have not told us what kind of cable you are using to connect the tippingpoint and the ASA. I suspect that it is a straight through cable and that the connection may need a cross over cable. Try changing the cable to cross over and let us know if it works better.
Rick
