BAT Error
Jun 20th, 2008
HI all,
I am facing the following error while trying to valdiate the IP Phones in BAT.
Validate Phones - Specific Details
Begin Time : 06/20/2008 23:07:27
Failure Details :
Device Name/MAC Address Error Code Error Description
2001 CSV contains more number of lines than are supported by the phone template.
Result Summary :
VALIDATE for 0 PHONE passed.
VALIDATE for 214 PHONE failed.
End Time : 06/20/2008 23:07:27
The CCM version is 6.0.1.3000-7
Thanks in advance...
thisisshanky Fri, 06/20/2008 - 09:47
  • Purple, 4500 points or more
So how many lines are you adding for each of these phones in the bat file. This needs to match with the line template (BAT) you created for the BAT phone template. (Dont confuse BAT phone template with Phone Button Template).
simranjeet.singh Fri, 06/20/2008 - 20:33
hi i am using bat.xlt to create the csv file.
i am creating two lines in bat file.
i have created a bat template for 7940 with two lines.
while validating i am selecting the the bat file with two lines and the bat phone template for 7940 with two lines.
i tried with single line also.
but i am getting the same error all the times
simranjeet.singh Fri, 06/20/2008 - 23:27
hi
the problem is solved..
i had forgotten to give the name for line template in phone template.
