Jaime Valencia Sat, 06/21/2008 - 16:06
  • Cisco Employee,
  • Hall of Fame,
    2011
exactly what are you trying to configure?
your post does not provide enough information to help you
javalenc
mohammedanasshaikh Mon, 06/23/2008 - 05:28
i hav a 2801 router which has some ip phones connected to it, and i hav a call manager 6.x i want to interconnect these two in such a way that the call manager becomes a publisher nd the 2801 is the subscriber that is the 2801 will send the call records to the call manager...
Jaime Valencia Mon, 06/23/2008 - 18:31
  • Cisco Employee,
  • Hall of Fame,
    2011
ok, you can have the phones with either CUCM or CME, but not with both. in any case what you would need to use is CUCM + SRST
the terms PUB and SUB are only used in CUCM environments, not with CME.
there's plenty of material within CCO
and here:
http://www.cisco.com/univercd/home/home.htm
since you're new you will need to start reading a lot if you really want to learn
javalenc
if this helps, please rate
