Moving-Intergrating CCM/Unity 3.X cluster to 4.2 cluster
Jun 20th, 2008
We are working on incorporating or upgrading a 3.2 cluster to 4.2. for CCM and Unity. Can we BAT the profiles User/Devices from one to the other. Also what are some of the challenges that we may encounter.
Rob Huffman Fri, 06/20/2008 - 18:21
Hi James,
I'm just going to speak to the CCM question for now (pretty complicated) Just as an FYI CCM 4.2 has been announced as EoL (see below) I really like 4.2(3) but I just wanted you to know (you may already :)
End-of-Life Milestones and Dates for the Cisco Unified CallManager Version 4.2
End-of-Sale Date
The last date to order the product through Cisco point-of-sale mechanisms. The product is no longer for sale after this date.
May 15, 2008
Last Ship Date:
App. SW
The last-possible ship date that can be requested of Cisco and/or its contract manufacturers. Actual ship date is dependent on lead time.
August 13, 2008
End of SW Maintenance Releases Date:
App. SW
The last date that Cisco Engineering may release any final software maintenance releases or bug fixes. After this date, Cisco Engineering will no longer develop, repair, maintain, or test the product software.
May 15, 2009
End of New Service Attachment Date:
App. SW
For equipment and software that is not covered by a service-and-support contract, this is the last date to order a new service-and-support contract or add the equipment and/or software to an existing service-and-support contract.
May 15, 2009
End of Service Contract Renewal Date:
App. SW
The last date to extend or renew a service contract for the product.
August 11, 2010
Last Date of Support:
App. SW
The last date to receive service and support for the product. After this date, all support services for the product are unavailable, and the product becomes obsolete.
May 15, 2011
End-of-Life and End-of-Sale Notices
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_eol_notices_list.html
For a CCM 3.2 to CCM 4.2;
This type of upgrade uses a multi-step approach to migrate the data from CCM 3.2 to 4.2(3). There are different considerations depending on whether or not the Servers are being replaced etc.
Upgrading Your Cisco Unified CallManager Server (When You Are Not Replacing Hardware)
You cannot upgrade directly from Cisco CallManager Release 3.2 or earlier to Cisco Unified CallManager Release 4.2. If your server runs a version of Cisco CallManager Release 3.2 or earlier, you must first upgrade every server in the cluster to the latest version of Cisco CallManager Release 3.3, 4.0, or 4.1 before you can upgrade to a version of Cisco Unified CallManager Release 4.2. For information on upgrading to Cisco CallManager Release 3.3, refer to the latest version of Upgrading Cisco CallManager Release 3.3.
Note If you are upgrading from Cisco CallManager 3.3, you must use the disks from the Cisco Unified CallManager 4.2(3) software kit.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_installation_guide_chapter09186a00807202d7.html
If all you want from the 3.2 database is the phone/user info, you may be able to use the BAT Export from 3.2 and then BAT Import on 4.2. Be careful with the actual BAT format between versions as they will not match exactly for sure. With some tweaking this would probably work. Try some example Export/Imports to fine tune the .csv or BAT.xlt details before going for the lot.
Hope this helps!
Rob
