C6k with 6748 - Qos
Jun 20th, 2008
  • Bronze, 100 points or more
on the 6748 blade, one port only connect to a gig port microsoft server, I want to set the speed at 100kbps...yes, you heard right 100kbps. Can I use any CatIOS Qos to do this? If not 100Kbps, what is the minimum bw?
aamercado Mon, 06/23/2008 - 07:02
I have CatIOS, not CatOS. Is there another solution?
Thx
