06-21-2008 04:16 AM
Hai,
thanks in advance,
i hav loaded my 3660 with Ios
c3660-ik9s-mz.124-13b and SDM 2.3
and configured as below
Router#sh run
Building configuration...
Current configuration : 2497 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
crypto pki trustpoint TP-self-signed-241257058
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-241257058
revocation-check none
rsakeypair TP-self-signed-241257058
crypto pki certificate chain TP-self-signed-241257058
certificate self-signed 01
quit
username xxx privilege 15 secret xxx
interface FastEthernet0/0
ip address 172.26.0.1 255.255.0.0
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
But i couldnt get into telnet Prompt, is there restriction for SDM login attempts
06-21-2008 04:49 AM
The only problem that I see is that both of your interfaces are administratively shut down.
Mark
06-21-2008 05:46 AM
a basic mistake done, thou it isnt working, any advise welcome
06-21-2008 06:05 AM
Can you verify that you are using a crossover cable, or a switch between the router and your PC? Also verify that you can ping the router from the PC, and the PC to the router.
06-22-2008 12:15 AM
anand
The reason that you can not access the router via telnet or via SDM is that the router has no active IP address for you to access. The only interface that is configured with an IP address is also shutdown:
shutdown
If you will no shutdown the interface then you should find that telnet, or SSH, or SDM should work.
[edit] I am not sure how, but when I saw the original post I did not see that there had been responses. After my response posted then I see that Mark has already responded with the same observation of the shutdown interface that I made (sorry for the duplication).
Anand - if you would post the output of "show ip interface brief" it would help us to understand what is happening here and to clarify the status of the interfaces.
Rick
06-24-2008 08:18 PM
sorry for the long delay
here is the sh ip int brief
Router#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 172.26.0.1 YES manual up up
FastEthernet0/1 10.10.10.1 YES manual up up
06-25-2008 03:16 AM
anand
Thanks for the additional information. It clearly shows that the interfaces are up / up and therefore are available. There obviously have been some config changes (no interface shutdown and the second interface has an address). Are you still having the problem with telnet and SDM? If so then the questions that Mark raised about are you able to ping the router from the PC become important.
Rick
06-25-2008 04:05 AM
Rick,
thanks for the reply and
i m able to ping as well telnet the router
but thru sdm its problem
its showing prompt for 3 failures that is
1 ping router
2 check ip address of router
3.ios of router supports sdm or not
above 2 are done,last 3rd i m not sureof
could we have to load the sdm also into ios
06-25-2008 04:31 PM
The last thing that I would check is your username/password. I know that you have sanitized your config for the post. Try entering this if it is already not this way.
username (username) privilege 15 secret 0 (password)
Or
username (username) privilege 15 password (password)
There is no secret password identifier (ie 0 or 5) next to secret in the posted config.
Mark
