bandwidth limitation
Jun 21st, 2008
Would you please tell me how I could limit my 2960 interfaces to 128kbps?
Best regards.
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Sat, 06/21/2008 - 07:13
Switches are not apt for that. You should impose bandwidth limitations on the router.
y-heidary Sun, 06/22/2008 - 02:42
I cant accept your answer, because in cisco2960 datasheet you can see that it is possible to limit bandwidth and the command is :
srr-queue bandwidth limit weight
this command limit bandwidth up to 10mbps
but my problem is :how to limit a port to 128kbps(less than 10mbps)?
Paolo Bevilacqua Sun, 06/22/2008 - 10:52
you should learn to be more respectful to answers like mine above, that are 100% factual and correct.
You have even found yourself the reason why a 2960 switch is not apt to limit bandwidth, still you are unable to accept this simple facts ?
Please come back when you've a more collaborative attitude in a professional forum like this, good look in the meanwhile.
y-heidary Mon, 06/23/2008 - 00:36
I am sorry if i didnt polite to you. i am full respectful to person like you as a teacher.
but the english is not my first language, so may be i cant write as plolie as a nation.
i am so sorry about that.
best regards.
Pravin Phadte Mon, 06/23/2008 - 07:38
I would suggest the post to be open unless someone comes out with the resolution or workaround for setting a bw on the port for 128 k.
srr-queue may work but not to the expected need there is a limitation for all.
This question was posted in LAN, Switching and Routing and was answered plz do not post the question in all the subtitles.
