PGW2200 password recovery & configuration
Jun 21st, 2008
i am working on cisco AS5350 we have install pgw200 which is connected to Seimens EWSD switch via ss7 AS5350 has SLT functinality we lost pgw200 password & need to configure few gatways with this pgw2200. need to know any one can help me this regard .
irisrios Thu, 06/26/2008 - 06:17
For password recovery:
Press the STOP and A keys simultaneously, or, on an ASCII terminal or emulator, send a to halt the operating system, if it's running.
Boot single-user from CD-ROM (boot cdrom -s) or network install/jumpstart server (boot net -s).
Mount the root partition on "/a". "/a" is an empty mount point that exists at this stage of the installation procedure. For example: #mount
/dev/dsk/c0t0d0s0 /a
If the mount command fails and since "/a" always exists, then you either typed in the wrong device, OR the system is seeing the root partition as something else.
Set your terminal type so you can use a full-screen editor, such as vi. You can skip this step if you know how to use "ex" or "vi" from open mode. If you're on a sun console, type "TERM=sun; export TERM"; If you are using an ascii terminal or terminal emulator on a PC for your console, set TERM to the terminal type for example: TERM=vt100; export TERM.
Edit the passwd file, /a/etc/shadow (or perhaps in older versions,
/etc/passwd) and remove the encrypted password entry for root.
Type: "cd /; then "umount /a"
Reboot as normal in single-user mode ("boot -s"). The root account will not have a password. Give it a new one using the passwd command.
http://www.cisco.com/en/US/docs/voice_ip_comm/pgw/9/release/note/rn932.html
http://www.cisco.com/en/US/products/hw/vcallcon/ps2027/products_configuration_example09186a008022e827.shtml
