Warning message
Rob Huffman Sun, 06/22/2008 - 08:36
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Kevin Porter Mon, 06/23/2008 - 04:21
Thanks for the replyRob, I have searched all over the new web site and cannot find CSA for UCCX. The link you sent was for UCCE (IPCC Enterprise). I guess I'll have to open a TAC Case...
Rob Huffman Mon, 06/23/2008 - 05:38
  • Hall of Fame,
    Founding Member
Hi Kevin,
OOPS my bad! I wasn't paying enough attention to the "X" in UCCX :) My understanding of this is that IPCC Express also known as CRA uses the same CSA Version/files as Communications Manager (CCM). This is why we can't locate specific versions for UCCX. Here are some references for this;
In addition to being specifically tuned for the Cisco Unified CallManager and Cisco CRS software, Cisco Security Agent for Unified CallManager provides support for many Cisco-approved, third-party applications. The agent also provides security for web and database services. In addition, CSA provides security checks for TCP/IP if you install the Network Shim, which serves as a host-based intrusion detection system. When a later version of the agent becomes available, Cisco strongly recommends that you install the later version.
Follow the installation instructions in this document to install CSA on all servers within the voice cluster, including Cisco Unified CallManager, Cisco CRS, Remote Database, voice, and speech servers. Do not install the agent on client machines.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/csa_token_ids/csaccm50.html
Installing Cisco Security Agent for Cisco
Customer Response Solutions
http://www.cisco.com/application/pdf/en/us/guest/products/ps5883/c1676/ccmigration_09186a0080262d47.pdf
Hope this helps!
Rob
Kevin Porter Mon, 06/23/2008 - 12:09
Thanks again. All the documentation you referenced all leads back to the same Download page. After doing some extensive folder diving, it appears that CallManager Versions 4.0, 4.1 and 5.0 reference "Security Agent System Software" in their respective links to software...
Man, what a pain in the behind...
kdamisch Tue, 06/24/2008 - 21:27
Did you ever find the link for the CSA agent for UCCX 5.x?
Kevin Porter Wed, 06/25/2008 - 05:19
Yes, I did. It is located under the CallManager Version 4.1 folder. Click on the link to 4.1 and there is an option for Security Agent. Version 3.0.9 is the latest for CCM 4.1 and UCCX 5.0...
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=3.0(9)&mdfid=278853938&sftType=Security%20Agent%20System%20Software%20for%20Unified%20Communications%20Manager/CallManager&optPlat=null&nodecount=2&edesignator=null&modelName=Cisco%20Unified%20CallManager%20Version%204.1&treeMdfId=278875240&treeName=Voice%20and%20Unified%20Communications&modifmdfid=null&imname=null&hybrid=Y&imst=N&lr=Y
araffill Mon, 08/11/2008 - 06:06
Thanks a lot for the CSA location.
Even I was looking for it.
Many Tx.
