Need help on voice Gateway
Jun 21st, 2008
Hi Friends. In the voice Gagtway, i can see 10 calls active, is it possible to find how many calls are outgoing calls or how many calls are incoming calls. pls explanin.
gogasca Sun, 06/22/2008 - 00:20
Sure, you can, use call active voice br command, normmaly there are 2 call legs for each call, find out the called, calling number and also incoming and outgoing dial-peer and that should help
