GBIC to SFP
Answered Question
Jun 22nd, 2008
Can I connect a GBIC port to a SFP port ?are there suitable fiber cords for the same?
Correct Answer by Jon Marshall about 8 years 8 months ago
Sumesh
Yes you can do this you just need a cable that is SC (GBIC end) to LC (SFP end).
You should be able to get this cable from your normal cable supplier although they may have to make them up.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Sun, 06/22/2008 - 07:10
Sumesh
Jon
