Configuration steps for TACACS+
Jun 22nd, 2008
Hi we are planing to install the Cisco ACS 4.2 with TACACS+ can any one send the configuation steps for ACS and Configuration steps that i have to do at Router & Switches
Overall Rating: 4 (1 ratings)
Marwan ALshawi Sun, 06/22/2008 - 18:25
it is easy
first install it on windows box then make a client on network section on the right, u have to make a client for evry device that u gonna use it for aaa, easy too, the device IP and shared secret ( and u have to choose the protocol u want such as on)
then make a server group on ur router which represent the ACS server (IP and the same shared secret)
then you can use this server group on you aaa configurations
for detailed config and every thing related to your question use the link bellow
please rate if useful
thank you
Jagdeep Gambhir Mon, 06/23/2008 - 04:54
Here are the commands,
Employ Authentication, Authorization, and Command Authorization on an IOS or set based
Router(config)# username [username] password [password]
tacacs-server host [ip]
tacacs-server key [key]
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa authorization config-commands
Note : Use "authorization command"only if you plan to setup command authorization.
