Upgrading Access Point
Jun 22nd, 2008
Can anyone help me to upgrade the autonomous access point to light weight mode?
AP : Cisco 1120
Should i give controller credentials ?
I have tried with Upgrade Tool and it is not happening,Also i am not getting any error.
Can anyone help me quickly ?
Senthil
jeromehenry_2 Mon, 06/23/2008 - 00:31
Yes you should give controller credentials for time synchronization. Does your 1120 have a MIC or SSC? You might need to add the certificate to the system if it is old enough to have SSC.
If it is in the same subnet as the controller, you might want to try to use a tftp server and try the archive download command from the AP.
Which version of the upgrade tool do you use?
What do you see on the AP console?
Tx
Jerome
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
