VMWare Virtual Network configuration guidance needed - CCM 5.1 VWWare
admin_2
Level 3
Level 3
I've loaded CCM 5.1 over VMware a while back and had this running but am now trying to bring up CCMadmin and have been unsuccessful.
The Virtual Networking parameters have been tried in every way I could possibly thing of and I am not able to get a default gateway via dhcp.
Please look at the attachment. It will show you every view of the configuration.
I can ping back and forth between the physical adapter but cannot bring up ccmadmin via http.
Please help if you can think of things for me to try.
Ray
Not applicable
I've tried to attach the 1.8MB file and it has failed twice now. Email me if you want to view the traces. Thanks
Not applicable
Tim Smith
Level 4
Level 4
Hi Ray,
Can you SSH to it?
You can ping the vmware machine from your pc?
Are all the basics in place? Firewall software etc? Nothing is blocking HTTPS or VMware?
What is your current virtual network setup?
If you want other devices to access the VM you will need to use bridged. The VM should have an IP in the same range as your physical adapter.
If you just want to access from your PC, you can use host only.
Cheers,
Tim
