X.25 Switching.
Jun 22nd, 2008
In current setup Customer is having Fujitsu routers installed And X.25 Switching is running between them. We want to replace the Legacy routers with Cisco Routers.
Please find the attached PPT for more details.
Please help me in the design.
Pulkit Sharma
ohassairi Sun, 06/22/2008 - 23:41
if you are looking for config example, it should be like this:
X25 routing
interface Serial0
no ip address
encapsulation x25 dce
clock rate 64000
interface Serial1
no ip address
clock rate 64000
x25 route 4321 interface Serial0
x25 route 1234 interface Serial1
pulkit.sharma@n... Sun, 06/22/2008 - 23:55
Thanks..
I tried this config and my Serial Interface is UP but I am not able to ping my next hop router Serial Interface.
Can you please help me in this.
Pulkit Sharma
ohassairi Mon, 06/23/2008 - 10:49
you said the routers will act as x25 switchers. so what ip you want to ping?
if you can add IP to the diagram and x25 addresses.
other question: why are you using 2 x25 switchers in serial. only one switcher could be enough
pulkit.sharma@n... Mon, 06/23/2008 - 20:47
I want to crete a setup exactly shown in my ppt.
Do you think in this case I wont require any IP address in the RTR-RTR serial interfaces.
If so then how my both end Servers will communicate with each other without any X.121 or IP address.
Regrds,
Pulkit
ohassairi Mon, 06/23/2008 - 21:02
i think if your servers has x25 addresses and not IP addresses, and they need to communicate using x25 packets only, so you do not need any IP address.
x25 switching just switch x25 packets at layer 2 like does public x25 service provider.
IP over x25 is an other thing. this works if your hosts use IP addressing and your wan network is x25.
so you sould have configs like i said:
rtr1:
X25 routing
interface Serial0
no ip address
clock rate 64000
interface Serial1
no ip address
encapsulation x25
clock rate 64000
rtr2:
X25 routing
interface Serial0
no ip address
clock rate 64000
interface Serial1
no ip address
clock rate 64000
x25 route 4321 interface Serial1
x25 route 1234 interface Serial0
then use debug x25 packets to troubleshoot the connexions
pulkit.sharma@n... Mon, 06/23/2008 - 23:16
Thanks once again,
As per the Customer they are running PVC from server to server.
Can you please let me know how the configuration will look like..
Pulkit
Pravin Phadte Mon, 06/23/2008 - 02:26
Hi Pulkit,
Try with this config.
First router.
interface serial 0
ip address 131.108.1.3 255.255.255.0
x25 map ip 131.108.1.4 0
x25 pvc 4 ip 131.108.1.4
Second Router.
interface serial 0
ip address 131.108.1.4 255.255.255.0
x25 map ip 131.108.1.3 0
x25 pvc 4 ip 131.108.1.3
Hope this helps,
Pravin
Pravin Phadte Mon, 06/23/2008 - 05:08
The below config worked fine for me in the lab network.
Router 1
interface serial0/0
(config-if)#encapsulation x25 dce
(config-if)#x25 address 311082194567
(config-if)#ip address 10.60.8.1 255.255.248.0
(config-if)#x25 map ip 10.60.8.2 311082191234 broadcast
Rouetr2
(config)#interface serial0/0
(config-if)#encapsulation x25 dte
(config-if)#x25 address 311082191234
(config-if)#ip address 10.60.8.2 255.255.248.0
(config-if)#x25 map ip 10.60.8.1 311082194567 broadcast
Let me know if it helps.
Pravin
