vlan in the wireless lan
daysleeper
Hi to all,
if i create 2 vlan and i configure 2 ssid one for each vlan, this two vlan are created only for the wireless interface? Or i need to reconfigure all the lan equipment for this 2 vlan?
If i configure 2 vlan and the relative ssid i need two bvi interface configured with two different ip-address or i can use only one bvi with one ip address?
Thanks and best regards,
Carlo S.
The vlans are not only created for the wireless interface but also for the ethernet. Then the ethernet interface has to be connected with a switch that supports vlans. After that, it's up to you to do whatever you want with the vlans you created.
You don't need 2 BVI IPs. You only need one to be able to manage the AP
