DMZ FTP server setup
Answered Question
Jun 23rd, 2008
ASA 5510 with 8.0(3)
Iam trying to configure DMZ network and configure for FTP server access.
The FTP access is fine but when I configure DMZ interface to access from inside network, the FTP access from outside does not work.
The problem is that we can login to FTP site and unable to list folders & files and get the error message and also internet access will not work.
If I remove the access-group entry on DMZ interface FTP works fine and able to list folders & files and internet access works fine.
I have attached the config and can some one help me to resolve this issue.
Chandru
Correct Answer by mohammed_moustafa about 8 years 10 months ago
how is it going with you, the problem is solved or what?
Overall Rating: 4.5 (2 ratings)
dhananjoy chowdhury Mon, 06/23/2008 - 04:12
  • Silver, 250 points or more
check the following
1. Whether the FTP server is in Active or passive mode ?
2. what packets / traffic are getting dropped from FTP server to the client outside?
mohammed_moustafa Mon, 06/23/2008 - 04:28
Hi dear,
The problem is mainly caused by the denial of reply back traffic comming from the your FTP server. so there are two sollutions: firest in the DMZ access list allow traffic from FTP server to any on FTP ports OR, configure traffic inspection, you can use the default ASA inspection:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 1500
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
I'm sure this will help.
Best regards,
ckuriyar74 Fri, 06/27/2008 - 00:25
It solved my issue, just miised traffic inspection. :)
