ACS 4.2 Replication
Jun 23rd, 2008
Hi Guys,
Is anyone having a problem with DB replication on 4.2?
I have both my ACS servers added in the network devices with correct keys set.
i have set one to send and the other to recieve in the db replication settings, I have also set the partner on the sending device and set the accept from on the receiving end correctly.
I can ping between the two boxes, however I get a no response error on the sending ACS.
I get nothing in the logs of the receiver?
Any Ideas??
Cheers
Scott
Jagdeep Gambhir Mon, 06/23/2008 - 04:48
  • Red, 2250 points or more
Scott,
Please make sure that replication is setup correctly.
1) Make sure that you are not replicating over NAT. Replication over NAT does not work because the IP is used as part of the server authentication
2) Next, check to make sure that you are not sending or receiving the distribution table. On the primary server, the distribution table should not be checked in the send list, and on the secondary, the distribution table should not be checked for receive.
3) Then I would like you to check in the secondary server's partner list, to make sure that the primary is not listed. You should not enter the primary server into the partner list on the secondary server. However, the primary server should have all secondary servers listed in its partner list.
4) Ensure that the secondary server has it's replication scheduling set to "manual".
5) Please verify that your servers are all running exactly the same ACS version and build.
6) Also let me know if we have any firewall in between two acs servers.
~JG
scott-goodwin Mon, 06/23/2008 - 05:37
HI,
There is no firewall between the hosts, also no Nat.
I have checked the settings and they are as you explain.
Both servers are built from the same 4.2 media build with no patches applied.(as per another of your posts ;))
Still getting same message.
Scott
Jagdeep Gambhir Mon, 06/23/2008 - 06:06
Scott,
Is it a new installation or it stopped working after the upgrade to 4.2 ?
Please ensure port 2000 is open. Also if possible can you sniff the primary and secondary acs ports ? That will let us know if any traffic is hitting secondary acs.
From primary sniff we can confirm destination IP of replication traffic.
~JG
scott-goodwin Fri, 07/11/2008 - 01:31
No we haven't upgraded its a new installation.
I will sniff the traffic however it looks like the traffic never gets to sent or get lost in transit.
Will let you know outcome of capture.
Scott
scott-goodwin Fri, 07/18/2008 - 00:40
I have now sniffed the traffic and the Secondary ACS is sending back an RST, however all is configured up correctly.
Any Ideas
Scott
Jagdeep Gambhir Fri, 07/18/2008 - 04:50
Scott,
Do you see any "malformed packet" during the tcp handshake ?
Do we have multiple NIC on server ?
Can you send me sniffer trace ?
~JG
