Cisco 1720 issue
Answered Question
Jun 23rd, 2008
I bought myself a CCNA kit containing 2 x 1720, 1 x catalyst, 1 x 2600.
I've managed to break one of the 1720s by altering a setting in the 'conf Memory'
Now, when ever it tries to boot up, I get
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
C1700 platform with 49152 Kbytes of main memory
And prompts me with "rommon 2>"
monitor: command "reboot" not found
rommon 5 > ?
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dis display instruction stream
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
tftpdnld tftp image download
unalias unset an alias
unset unset a monitor variable
xmodem x/ymodem image download
rommon 6 > reset
Does anyone know how I can fix this issue, or where I download the files to be able to re-image the router.
Hopefully then I can complete my course work ;O)
Dave
Correct Answer by DeonLouwBotha about 8 years 8 months ago
Hi Dave,
No problems in helping we all start and break things at some point :-)
To use the ROM monitor, you will be connected with a PC using the console port but this leaves the RJ45 ethernet port free on the router and PC for TFTP.
You will be using Console RJ45 (Router) -> Serial (PC) connectivity. If you are using an original cable it's a blue coloured cable with a RJ45 one end and a serial connector on the other.
Now connect a network cable to your PC and then the other end to the 10/100BASE-TX Fast Ethernet port (RJ-45) on the router. (Rommon should look on this port, there is however a note in one of the links I sent that a "10BASE-T Ethernet Port is not active in ROM monitor mode" there is however only 1 x 10/100BASE-TX ethernet port on the 1720's so I don't know exactly how this applies)
Set a static IP address and subnet on your PC (10.0.0.1, 255.255.0.0) use the "SET" command in ROMMON on the router to set the needed variables to get it working IP address (10.0.0.2), subnet (255.255.0.0), defaut gateway (10.0.0.1), TFTP Server (10.0.0.1), IOS Image (C1700-xx-xxx-xx.bin)
C1700-xx-xxx-xx.bin - replaces the xxxx with the relevant information.
Hope this helps and answers you questions
Deon
Overall Rating: 5 (2 ratings)
hb21l6Cisco Mon, 06/23/2008 - 03:21
I've tried this solution
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00800a750e.shtml
rommon 5 > confreg
Configuration Summary
enabled ar
load rom after netboot fails
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-C1700
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
disable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
enable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot character
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[2]: 2
enabled are:
console baud: 9600
rommon 6 > ?
But this doesnt work either.
Dave
DeonLouwBotha Mon, 06/23/2008 - 04:11
Hi Dave,
Thats what I said in my first reply.
Post back if this doesn't solve your problem.
Deon Louw Botha
hb21l6Cisco Mon, 06/23/2008 - 04:17
Hi Deon Louw Botha
Thanks for the quick reply.
I don't have a new IOS, not sure where to get them from. I have found a document on this site that explains how to copy the image from another router, I was going to give this a try this evening.
Hopefully this will solve it.
Fingers crossed.
Dave
DeonLouwBotha Mon, 06/23/2008 - 05:00
Hi Dave,
If you have SmartNet and a CCO Login you can get IOS from Cisco.com click under support then download software then Cisco IOS Software.
Alternatively in your original post you said you had 2 routers both Cisco 1720's,
You can use the TFTP server (in other words the pc you have the TFTP software running on) to copy the IOS from one router to the other router if you don't have backups of IOS.
So the steps will be as follows to copy IOS from one to the other:
1. Install and configure the TFTP Server on a PC connected to your network, from your working Router ping the TFTP Server, if it fails then there is something wong, check that you have a default directory configured for the TFTP software etc. (get the TFTP Server working on the network)
2. Copy the working 1720 routers IOS to your TFTP Server, the IOS file is ussually something like c1700-**-**-****.bin and located in flash.
3. From your busted router in ROMMON use the set command to set the ROMMON variables (IP, Default Gateway, TFTP Server, etc) then use tftpdnld to get the IOS to copy from your TFTP Server.
You can try this TFTP Software it works well enough and its free:
http://www.solarwinds.com/products/freetools/free_tftp_server.aspx
The 1700 Series ROMMON guide
http://www.cisco.com/en/US/docs/routers/access/1700/1701/software/configuration/guide/rom_mon.html
How to copy from one device to another
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml
hb21l6Cisco Mon, 06/23/2008 - 05:22
Hi Deon Louw Botha
Many thanks for all the advice, I really appreciate it.
With my broken router not working, how will it see the tftp server on my PC? (no cat5e connectivity) can I transfer the image via the console cable?
Many thanks
Dave
Correct Answer
DeonLouwBotha Mon, 06/23/2008 - 06:03
Hi Dave,
Deon
hb21l6Cisco Mon, 06/23/2008 - 09:48
I've just got home and I was going to take a copy of the image from the working unit. This one is also doing the exact same thing,
Now I'm really stuck until I can find an image. _ i'll have to have a look through my work places comms rooms to see if we've got any old 1700s laying around. thou I guess we won't
Is there any other way to fix these routers without having an image?
thanks in advance
Dave
hb21l6Cisco Mon, 06/23/2008 - 09:55
panic over..
After several reboots, it decided to load the image. I'm now taking an image of it.
Cheers
Dave
DeonLouwBotha Mon, 06/23/2008 - 22:35
Hi Dave,
Thats great news was just doing some research on an alternative method other than needing an IOS image when your update came through.
All the stuff that you just did is kind of part of your CCNA, so it wasn't a waste of time.
Glad your back on track, good luck with your studies and best of luck with your exam.
Deon
DeonLouwBotha Mon, 06/23/2008 - 04:06
Hi Dave,
Have you tried going into "0 = ROM Monitor" and uploading a new IOS from your TFTP server?
DeonLouwBotha Mon, 06/23/2008 - 03:27
Hi Dave,
The error you are getting is when an un-aligned write is performed to the device close to an internal 64-byte boundary. This has been seen only when writing a crash-dump file (written when the system is already crashing for some other reason). Normal writes to the bootflash (such as downloading a new image) and operations such as squeeze, erase, and so on have not shown this failure.
http://www.cisco.com/en/US/ts/fn/100/fn11211.html
Solution to this is via ROMMON update/upgrade/restore the IOS you can use the other 1720 you have via TFTP download the IOS to your TFTP server then use the tftpdnld command to TFTP the IOS onto the busted router.
This should sort out your problem.
