Vlan Configuration Basics
Jun 23rd, 2008
Hi everyone,
Suppose that a router is connected to two switches(switch A and switch B).
SwitchA is connected to 2 pcs and a server.SwitchB is connected to 1 pc and 1 server.
When i didn't configure vlans on switches PDUs of pcs of switchA succesfully reached pcs of switchB.
After configuration of vlans pdus are unsuccesful to reach.
What must be done?
mahmoodmkl Mon, 06/23/2008 - 03:33
Is there a connection between switchA n SwitchB,if its then what port config is on that i.e its a access port or a trunk port.
What is the config of the ports on the siwtch to which the router is connected..I think u need to provide more details.
Faizan Shaikh Mon, 06/23/2008 - 04:52
Thanks Mahmood for your reply!
SwitchA and SwitchB are connected via router.
Anyways, i got the remedy for the problem by making them access ports.
can u tell me in brief what functions Access ports and Trunk ports perform?
