VG224 wtih super g3 fax machines
Jun 23rd, 2008
Getting read to put in a vg224. Will register to ccm as mgcp and will use passthru mode. Will I have to do anything on the existing super g3 fax machines? My hope is that I don't have to modify their speed nor turn off ECM. I just want to let tones pass through and negotiate speed at the fax.
Any and all advise is greatly appreciated.
thank you
victor2008 Mon, 06/23/2008 - 09:06
I appreciate that tip.
But still need clear understanding if faxes are going to go through to Super G3 fax machines without any intervention? Or do I need to go on the fax machines and turn off Error Correction MOde and/or turn the speed down to 14.4?
I'm using mgcp and modem passthrough NSE
thanks
