Error RME Upgrade LMS2.6 -> LMS3.0
Jun 23rd, 2008
Hello
at the moment i'd try to take a Remote Upgrade from LMS2.6 -> LMS3.
After the installation of CiscoWorks 3.0 and the Backup of the data from LMS2.6 i strated the Restore.
At the part restoring RME (after 95%) a errormessage appears and the Restore stopped. Now i'm afraid about lost data an the new LMS System.
Have anyone a idea ?
Here the relevant part of the migration.log
Warning - No current logger set
23/Jun/2008 11:13:00:902 49390 [main] ERROR com.cisco.nm.rmeng.migration.MigrMain 317 -
com.cisco.nm.rmeng.dcma.utils.DCMAUtilException
at com.cisco.nm.rmeng.dcma.utils.DCMAPreferences.putPreferences(DCMAPreferences.java:903)
at com.cisco.nm.rmeng.dcma.utils.DCMAPreferences.setCCRValue(DCMAPreferences.java:209)
at com.cisco.nm.rmeng.dcma.utils.DCMAPreferences.setArchiveDir(DCMAPreferences.java:685)
at com.cisco.nm.rmeng.migration.DcmaDataMigrator.doRestore(DcmaDataMigrator.java:285)
at com.cisco.nm.rmeng.migration.DcmaDataMigrator.doMigration(DcmaDataMigrator.java:155)
at com.cisco.nm.rmeng.migration.MigrMain.callAppDoMigration(Unknown Source)
at com.cisco.nm.rmeng.migration.MigrMain.main(Unknown Source)
23/Jun/2008 11:13:00:902 49390 [main] FATAL com.cisco.nm.rmeng.migration.MigrMain ? - Operation could not be proceeded..
23/Jun/2008 11:13:00:902 49390 [main] FATAL com.cisco.nm.rmeng.migration.MigrMain ? - Reason is :null
Thanks in advanced
Mario
Overall Rating: 3 (1 ratings)
Joe Clarke Mon, 06/23/2008 - 09:51
This looks like an issue with the NMSROOT/MDC/etc/regdaemon.xml file. However, I am at Networkers right now, and I can't dig into this. I suggest you open a TAC service request, and include this regdaemon.xml file as well as the full migration.log.
MarioLieb Fri, 06/27/2008 - 04:33
thanks for your answer. I'd fixed the problem. I am not sure which update was the reson i installed the Updatepack lms30_dec07_update_win_k9. Now the following versions running on my LMS- System
CiscoWorks Common Services 3.1.1
Campus Manager 5.0.3
CiscoView 6.1.7
CiscoWorks Assistant 1.0.1
Device Fault Manager 3.0.2
LMS Portal 1.0.1
Resource Manager Essentials 4.1.1
After this Updates i made an Restore which works fine
Thanks Mario
