cme 4.x + isdn problem
Jun 23rd, 2008
Hi all! I`ve got overhellming my head problem. I managed to set up voip network with AA and voicemail, now i want conections for outside calls throught ISDN (bri) interface. I can call out but when call is picked up no sound is heard at all. I do also have a problem with call in. there is one signal and then its answered by AA but again i can`t heatr any voice. Please help.
paolo bevilacqua Mon, 06/23/2008 - 04:48
  • Hall of Fame,
    Founding Member
You need to post voice related config to let others being able to help you.
tomasz1983 Mon, 06/23/2008 - 04:54
OK, here it comes:
isdn switch-type basic-net3
voice-card 0
voice service pots
supplementary-service qsig call-forward
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
supplementary-service h450.12
h323
sip
voice translation-rule 10
rule 1 /.+/ /81745xxxx/
voice translation-rule 20
rule 1 /.+/ /1999/
voice translation-profile IN
translate called 20
voice translation-profile OUT
translate calling 10
interface BRI0/3/0
no ip address
no logging event link-status
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
voice-port 0/3/0
translate calling 20
no vad
compand-type a-law
cptone PL
connection plar 1999
voice-port 0/3/1
no vad
compand-type a-law
cptone PL
dial-peer voice 10 voip
destination-pattern 1[1,9][1,9][1,9]
session protocol sipv2
session target ipv4:192.168.10.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
destination-pattern 0.........
translate-outgoing calling 10
port 0/3/0
forward-digits all
dial-peer voice 2 pots
translation-profile incoming IN
incoming called-number 81745xxxx
port 0/3/0
forward-digits all
telephony-service
load 7960-7940 P0030702T023
load 7911 SCCP11.8-2-2SR1S
max-ephones 20
max-dn 20
ip source-address 192.168.10.1 port 2000
timeouts interdigit 5
voicemail 1111
max-conferences 4 gain -6
web admin system name eeKyy password eeKyy
web admin customer name eeKyy1 password eeKyy1
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 0T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jun 23 2008 08:43:42
ephone-dn 1 dual-line
number 1001
description PIERWSZY
name PIERWSZY
call-forward busy 1111
call-forward noan 1111 timeout 10
ephone-dn 2 dual-line
number 1002
description DRUGI
ephone-dn 3 dual-line
number 1003
description IPcommunicator
ephone-dn 18
number 1998....
mwi on
ephone-dn 19
number 1999....
mwi off
ephone 1
mac-address 001B.xxxx.xxxx
username "user1" password cisco
type 7940
button 1:1
ephone 2
mac-address 001A.xxxx.xxxx
username "user2"
type 7911
button 1:2
ephone 3
mac-address 0030.xxxx.xxxx
type CIPC
button 1:3
pin 1111
paolo bevilacqua Mon, 06/23/2008 - 05:01
  • Hall of Fame,
    Founding Member
under DP 2, you need "direct-inward-dial".
Hope this helps,please rate post if it does!
tomasz1983 Mon, 06/23/2008 - 05:11
nope it didn`t help, can make call but no voice in handset at all :(
paolo bevilacqua Mon, 06/23/2008 - 05:16
  • Hall of Fame,
    Founding Member
May be AA on CUE is not set correctly. Try changing translation rule so that call is sent to a phone and you should be able to talk.
pcameron Mon, 06/23/2008 - 05:17
  • Cisco Employee,
Most common cause of one way voice is a routing issue. This could be the phone or the router does not have a return router between each other, or the source address of one device is not reachable from the other.
We need to know if the phones are on the same local network as the CME system , or are they on remote IP subnets.
Otherwise paste your FULL config so we can check how the rest of the router has been set up.
Paste your
tomasz1983 Mon, 06/23/2008 - 05:27
My 2801 router is gateway to pstn (through isdn). Dialling is OK. I mean if I dial my mobile number it rings but when I pick up no sound in it. All ip phones are connected to this router, and AA is aim-cue it is working fine for ip phones.
paolo bevilacqua Wed, 06/25/2008 - 04:45
  • Hall of Fame,
    Founding Member
Can you take a "debug isdn q931" with "term mon" for when you call out and no voice is heard.
tomasz1983 Wed, 06/25/2008 - 05:05
here it comes:
Jun 25 15:00:43.119: ISDN BR0/3/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling
num 817455260
Jun 25 15:00:43.123: ISDN BR0/3/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called
num 0503729170
Jun 25 15:00:43.123: ISDN BR0/3/0 Q931: TX -> SETUP pd = 8 callref = 0x09
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number
Router# i = 0x0080, '817455260'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0503729170'
Jun 25 15:00:43.355: ISDN BR0/3/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x89
Channel ID i = 0x89
Exclusive, B1
Router#
Jun 25 15:00:47.999: ISDN BR0/3/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x89
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jun 25 15:00:48.211: ISDN BR0/3/0 Q931: RX <- ALERTING pd = 8 callref = 0x89
Router#
Jun 25 15:00:54.535: ISDN BR0/3/0 Q931: RX <- CONNECT pd = 8 callref = 0x89
Facility i = 0x91A151020206B002011F3048301E0A0100A11981032E2E2EA206810164820101830101
A40781020C9882010030120A0102A20D81032E2E2EA20681010082010130120A0104A20D81032E2E2EA2068101008
20101
Protocol Profile = Remote Operations Protocol
0xA151020206B002011F3048301E0A0100A11981032E2E2EA206810164820101830101A407810
20C9882010030120A0102A20D81032E2E2EA20681010082010130120A0104A20D81032E2E2EA206810100820101
Component = Invoke component, Unsupported operation
Display i = 'FIX: 1 PERIOD: 0:00:32 - 1'
Date/Time i = 0x0806190F02
Date (yr-mm-dd) = 08-06-25
Time (hr:mnt:sec) = 15:02:174
Jun 25 15:00:54.539: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 0503729170 N/A
Router#
Jun 25 15:00:54.539: ISDN BR0/3/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x09
Jun 25 15:00:54.567: ISDN BR0/3/0 Q931: RX <- FACILITY pd = 8 callref = 0x89
Facility i = 0x91A113020206B1020122300AA1053003020101820100
0xA113020206B1020122300AA1053003020101820100
Invoke Id = 1713
Operation = AOCDChargingUnit
Router#
Jun 25 15:01:00.539: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 0503729170 N/A
Router#
Jun 25 15:01:04.419: ISDN BR0/3/0 Q931: RX <- INFORMATION pd = 8 callref = 0x89
Display i = 'LICZBA JEDNOSTEK - 1'
Router#
Jun 25 15:01:26.867: %DSMP-3-DSP_TIMEOUT: DSP timeout on DSP 0/1:1: event 0xDC, DSMP timed ou
t, while waiting for statistics from the DSP. DSMP State = S_DSMP_COLLECTING_STATS, chnl info
(0, 1, 1)
Jun 25 15:01:26.867: %ISDN-6-DISCONNECT: Interface BRI0/3/0:1 disconnected from 0503729170 ,
call lasted 32 seconds
Router#
Jun 25 15:01:26.867: ISDN BR0/3/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x09
Cause i = 0x8090 - Normal call clearing
Jun 25 15:01:27.011: ISDN BR0/3/0 Q931: RX <- RELEASE pd = 8 callref = 0x89
Facility i = 0x91A112020206B302012430093007A1053003020102
0xA112020206B302012430093007A1053003020102
Invoke Id = 1715
Operation = AOCECharging Unit
Display i = 'LICZBA JEDNOSTEK - 2'
Jun 25 15:01:27.015: ISDN BR0/3/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x09
Router#
paolo bevilacqua Wed, 06/25/2008 - 05:14
  • Hall of Fame,
    Founding Member
Hi, I see that is suspicious:
(0, 1, 1)
Which exact IOS are you running ?
paolo bevilacqua Wed, 06/25/2008 - 05:23
  • Hall of Fame,
    Founding Member
Please upgrade to 12.4(11)XJ4 and check again.
tomasz1983 Fri, 06/27/2008 - 01:28
I did upgrade to version: c2801-ipvoicek9-mz.124-11.XJ4 but still the same problem exists :( any help please
paolo bevilacqua Fri, 06/27/2008 - 03:04
  • Hall of Fame,
    Founding Member
Do you still see the same message in log ?
If so it can be an HW problem and you should try a different PVDM2 module.
tomasz1983 Fri, 06/27/2008 - 04:05
i doubt i could be HW problem because when i force phones to use different codecs: one using g711ulaw and second using g729r8 voice is OK. So i think that router in this case is using dsp in proper way. Maybe i should configure dsp farm on my router, but i don`t know how. Please help.
paolo bevilacqua Fri, 06/27/2008 - 04:12
  • Hall of Fame,
    Founding Member
Hi, when you configure phones with different codecs, router doesn't enter the media path unless you also configure "dspfarm-assist" and transcoding.
You could also try removing the PVDM2 and would observe that the phones are still able to talk to each other even when configured with different codecs.
Perhaps you can take some DSP specific debugs to see if other error messages are thrown.
tomasz1983 Fri, 06/27/2008 - 04:15
for example what debug would you like to see in order to help me???
paolo bevilacqua Fri, 06/27/2008 - 04:17
  • Hall of Fame,
    Founding Member
Sorry, I can't really tell what would be the "right" one because such a problem never occurred to me. Form the error message above I can tell that something is wrong with the DSP HW, but nothing more specific.
tomasz1983 Fri, 06/27/2008 - 04:29
i need to be sure that it is the hardware problem i don`t have different dsp module to use. Can write me how to force phones to use different codec with dsp assist.
paolo bevilacqua Fri, 06/27/2008 - 04:34
  • Hall of Fame,
    Founding Member
You need to configure transcoding as per the administrator guide.
I think that is an overkill just to test an PVDM2 module that should be replaced by simple request from the vendor you bought it from.
