Unable to assign an IP address to AP 1131AG (AIR-LAP1131AG-E-K9)
Jun 23rd, 2008
Hi Dear,
I am unable to assign a new IP address to the AP 1131AG (AIR-LAP1131AG-E-K9) using the console port.
It seems, this AP is booting not on AP> but on the different prompt and the different commands are not recognized.
Configure terminal
Interface bvi1
Ip address xxxx.xxxx
Could you please help me?
Rob Huffman Mon, 06/23/2008 - 05:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mohamed,
Hope all is well :)
The problem here is with the model of 1131 that you are trying to use. The designation of "LAP" in AIR-LAP-1131 etc means that this is a Lightweight AP and does not contain an IOS. Thus, this cannot be configured as an IOS or Autonomous AP can.
These LAP - Lightweight AP's are for use with Wireless Lan Controllers in the Lightweight deployment model. You can either send this LAP back to Cisco in trade for the Autonomous IOS version AIR-AP1131AG-A-K9 or put an IOS on it using this method.
Try this method using the AP's mode button and a TFTP setup;
Here is a conversion method;
Reverting the Access Point Back to Autonomous Mode
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html#wp161272
You can convert an access point from lightweight mode back to autonomous mode by loading a Cisco IOS Release that supports autonomous mode (Cisco IOS release 12.3(7)JA or earlier). If the access point is associated to a controller, you can use the controller to load the Cisco IOS release. If the access point is not associated to a controller, you can load the Cisco IOS release using TFTP.
Using a TFTP Server to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
Step 4 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 5 Disconnect power from the access point.
Step 6 Press and hold MODE while you reconnect power to the access point.
Step 7 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 8 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9 After the access point reboots, reconfigure it using the GUI or the CLI.
From this doc;
Hope this helps!
Rob
drewgeeing Thu, 07/10/2008 - 21:36
Actually you can manually assign a static IP address in LWAPP mode by entering "enable" mode and config the IP address by:
lwapp ap ip
Similiarly you can enter a default-gateway, hostname and WLC Controller IP address.
Cheers
mferhai Thu, 07/10/2008 - 23:33
Can i do it without upgrading the IOS software in LWAPP?
MF
Scott Fella Fri, 07/11/2008 - 14:34
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
If you don't have a wireless lan controller, then you need to convert the ap's to autonomous.
Here is a link to do that:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
