Cisco 851 SDM Firewall Issue.
Jun 23rd, 2008
I have recently purchased 851 router. But i am facing issues while configuring it from SDM every thing is ok i have assigned Ip to my vlan and wan port the only issue is ,while configuring the firewall auto policies it gives me strange errors like there isnt any 2nd port other than vlan or some time it gives errors while applying inspect polocies.
hadbou Fri, 06/27/2008 - 02:52
  • Bronze, 100 points or more
Check if the verson of ios used in Cisco 851 is 12.3(8)YI and later as SDM is supported in these version of IOS.
Refer the "Cisco Router and Security Device Manager 2.5 User Guide" present in the following url for more information on SDM issues:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/SDM25UGD.html
