Connecting a Netgear FSM726 to a Cisco Switch
Jun 23rd, 2008
Hi All
I am in the process of connecting a Netgear FSM726 to a Cisco Switch. When I do this, with auto/auto on the Switch end, it keeps coming up as err-disabled.
I have done the following:
1. Removed spantree portfast.
2. Change the port to 100/Full
3. Moved the ports on the Netgear and Cisco Switch around
But it still err-disables the port.
Please help.
cyphur353 Mon, 06/23/2008 - 07:10
What kind of cable are you using?
Also, have you tried hard-coding both switches to 100/full?
qwertys21 Mon, 06/23/2008 - 07:20
I am not able to connect into the Netgear switch only the Cisco Switch. I am using a straight through cable. O gosh, I am suppose to use a Cross over, not so?. It says aut ouplink and I thought it was auto ( mdi/mdix).
cyphur353 Mon, 06/23/2008 - 07:25
Try a crossover cable, see how that works out.
qwertys21 Mon, 06/23/2008 - 07:25
I have just used a Cross over cable and it is stil err-disable the port.
