Sanity-Check of QoS over ATM
Jun 23rd, 2008
Everyone,
I believe this is right but my understanding of the intricacies of ATM is fuzzy enough that I would like confirmation.
Here is the scenario: 2 sites connected via a sometimes-congested 4mb ATM (4 T1's) link and all traffic is given a DSCP at ingress to the network as follows:
Voice and VTC signaling traffic: cs3
Voice Media Traffic: ef
VC Media : AF41
Everything else: 0
I need to:
Provide a LLQ for the Voice media and guarantee at least 256Kb BW
Guarantee at least 45k for VC and voice signaling
Guarantee at least 450k for VTC
Fairly handle whatever BW is left for everything else
Here is my config:
class-map match-all VC
match dscp af41
class-map match-all voice-rtp
match dscp ef
class-map match-all voice-signal
match dscp cs3
policy-map EC
class voice-signal
bandwidth 45
class voice-rtp
priority 256
class VC
bandwidth 450
class class-default
interface ATM3/ima2
description "IMA links to EC"
ip address 158.187.137.21 255.255.255.252
ip pim sparse-dense-mode
ip nat inside
ip virtual-reassembly
ip route-cache flow
load-interval 30
no atm ilmi-keepalive
crypto map RK-EC-IMA
pvc 0/16
protocol ip 158.187.137.21 broadcast
protocol ip 158.187.137.22 broadcast
service-policy output EC
First, does anyone see any issues with this working and second, what commands can I use to verify that it is doing what I think it should?
Nathan Spitzer
Joseph W. Doherty Mon, 06/23/2008 - 09:18
One issue I've found, on many of the non-7500 platforms, class-default FQ appears to distort the minimum bandwidth allocations for other non-LLQ classes. To avoid this, I either just use LLQ and class-default with FQ, or switch class-default to FIFO. If you chose to just use LLQ and class-default FQ, you could move your other classes to LLQ and/or allow them in class-default which normally uses WFQ (NB: where they should obtain more bandwidth because of their higher ToS markings vs. BE marked flows).
On ATM links, at least with some IOS revs., when supporting real-time traffic, you might also need to decrease the tx-ring-limit. For 4 Mbps, the minimum setting might be acceptable.
"Show policy-map interface output" should indicate how the policy is working.
PS:
Further on the subject of "working", I wonder about, configured on the ATM interface, "ip pim sparse-dense-mode", "ip nat inside", and "crypto map RK-EC-IMA". Depending on the type of ATM PVC, you might also consider defining a point-to-point subinterface. Also, if your PVC is something like a vbr with a SCR much smaller than the PCR, you might need to examine how that might impact your real-time traffic.
