LMS 2.6 ANI Server Never Started
Jun 23rd, 2008
Can anybody help me plz,
I successfully install and register LSM 2.6,my DCRServer Running Normally but my Campus Manager is not working at all. When I checked in the Process Management under admin>server>commonservices I find my most services is not started ANIServer, jrm, CTMjrm, Change Audit and more. I try to start the service but it is not starting, I install all the updates but still facing same problem.
Any help will be highly appreciated.
Thanks in Advance.
Khan
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 06/23/2008 - 09:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the output of the pdshow command.
mohdatherkhan Mon, 06/23/2008 - 10:08
Thanks for your reply.
I installed it on windows machine, form where I can get this command output.
KHAN
Joe Clarke Mon, 06/23/2008 - 10:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Run pdshow from the DOS shell. Capture the output.
Joe Clarke Mon, 06/23/2008 - 11:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
EDS is waiting to initialize which points to either a port conflict or a hostname change. Was the hostname of this server changed after LMS was installed? With LMS shutdown, please post the output of netstat -a -n -o -b.
mohdatherkhan Mon, 06/23/2008 - 14:37
Yes, hostname was changed after Common services was installed. But after the hostname changed i uninstalled all Cisco works and did fresh installation for all Cisco works from beginning.
Please find the attached netstat output for all.
sorry its huge file.
Khan
Joe Clarke Mon, 06/23/2008 - 14:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I need a netstat -a -n -o -b with dmgtd shutdown.
mohdatherkhan Mon, 06/23/2008 - 15:00
Do you mean Cisco works Daemon Manager service from the services.
Khan
Joe Clarke Mon, 06/23/2008 - 15:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes. Shutdown the CiscoWorks Daemon Manager, then collect the netstat output.
Joe Clarke Tue, 06/24/2008 - 07:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The port that needs to be free is free, so this is something else. I don't have time to analyze logs right now, so I suggest you open a TAC service request, and provide them the EDS.log as well as the output you've already collected.
mohdatherkhan Tue, 06/24/2008 - 07:33
Thanks a lot dear, I will open a TAC request now. By the way how can i take only EDS log so i can provide them all the logs EDS as well as the output which i send it to you last.
Khan
