ACE - Class-maps
Answered Question
Jun 23rd, 2008
I want to load balance traffic to a VIP based on client source address. Here is what I had in mind:
access-list special-25 extended permit tcp host 10.20.138.18 host 10.20.96.19 eq 25
access-list special-25 extended permit tcp host 10.20.138.30 host 10.20.96.19 eq 25
access-list special-25 extended permit tcp host 10.20.138.40 host 10.20.96.19 eq 25
access-list special-25 extended permit tcp host 10.20.254.88 host 10.20.96.19 eq 25
access-list internal-25 extended permit tcp 10.20.0.0 0.0.255.255 host 10.20.96.19 eq 25
access-list internet-25 extended permit tcp any host 10.20.96.19 eq 25
class-map match-any INTERNET-MAIL
2 match access-list internet-25
class-map match-any INTERNAL-MAIL
2 match access-list internal-25
class-map match-any SPECIAL-MAIL
2 match access-list special-25
class-map match-all VIP-MAILGATE-25
description MAILGATE INTERNAL 25
2 match virtual-address 10.20.96.19 tcp eq 25
serverfarm host mailgate-zero
description INTERNET MAIL
failaction purge
rserver mailgate-1
rserver mailgate-2
rserver mailgate-3
rserver mailgate-4
serverfarm host mailgate-one
description INTERNAL MAIL
failaction purge
rserver mailgate-5
rserver mailgate-6
serverfarm host mailgate-two
description I DON'T KNOW MAIL
failaction purge
rserver mailgate-8
policy-map type loadbalance first-match MAILGATE-POLICY
class SPECIAL-MAIL
serverfarm mailgate-two
class INTERNAL-MAIL
serverfarm mailgate-one
class INTERNET-MAIL
serverfarm mailgate-zero
policy-map multi-match CLIENT-VIPS
class VIP-MAILGATE-25
loadbalance vip inservice
loadbalance policy MAILGATE-POLICY
loadbalance vip icmp-reply active
The problem with this design is the policy-map MAILGATE-POLICY won't accept anything but the "class-default".
Any ideas how can I make this work?
Milo
Correct Answer by Gilles Dufour about 8 years 11 months ago
Milo,
you need to create a class-map of type http.
Sounds weird but this is the way to do it.
You can then match using a 'match source-address' command.
You can't specify the destination with an acl, but this traffic would normal hit a vip anyway this will set the destination.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 06/23/2008 - 08:07
  • Cisco Employee,
Milo,
Gilles.
meckel Mon, 06/23/2008 - 10:38
Gilles,
You're right, it does sound weird. However, it appears to work (the commands weren't rejected anyway). Now as soon as I get time on the real servers I test it out. Here's my modified config with your suggestion:
class-map type http loadbalance match-all INTERNAL-MAIL-TEST
10 match source-address 10.20.0.0 0.0.255.255
class-map type http loadbalance match-any SPECIAL-MAIL-TEST
10 match source-address 10.20.138.18 255.255.255.255
15 match source-address 10.20.138.30 255.255.255.255
20 match source-address 10.20.138.40 255.255.255.255
25 match source-address 10.20.254.88 255.255.255.255
class-map match-all VIP-MAILGATE-TEST-25
description MAILGATE-TEST.NAU.EDU SMTP MAIL
2 match virtual-address 10.20.96.36 tcp eq smtp
policy-map type loadbalance first-match MAILGATE-POLICY-TEST
class SPECIAL-MAIL-TEST
serverfarm mailgate-two-test
class INTERNAL-MAIL-TEST
serverfarm mailgate-one-test
class class-default
serverfarm mailgate-zero-test
class VIP-MAILGATE-TEST-25
loadbalance policy MAILGATE-POLICY-TEST
Thank you!
Milo
