Adding more keepalives
Jun 23rd, 2008
I've have several services defined like so:
service sclivelink002:81
ip address 10.5.55.132
port 81
keepalive frequency 2
keepalive retryperiod 2
keepalive port 2199
keepalive type tcp
protocol tcp
add ssl-proxy-list SSL1
active
My question is how can I add addition keepalive ports to this service. I want to monitor it via pings to port 80 as well. I've looked at the 'ap-kal-pinglist' scripts, but just not sure how to modify it for additional ports. What about defining a critical service, can I do that ?
I'm looking for something like:
keepalive port 80, 81, 2199
Any info. would be great.
Thx,
Manjit.
Overall Rating: 5 (1 ratings)
mduhra Mon, 06/23/2008 - 09:05
Gilles,
The numbers in quotes, do I change them for my specific ports.
For ex)
set OUT-OF-SOCKETS "785"
set NO-CONNECT "774"
if ${ARGS}[#] "LT" "2"
socket connect host ${SERVICE} port ${TCP-PORT} tcp 2000
Also, how do I apply the script once created.
Cheers!!
Gilles Dufour Mon, 06/23/2008 - 10:43
  • Cisco Employee,
don't change anything.
Copy the script in a file and copy it to your CSS via ftp into the script directory.
You then call the script from the service and provide the parameters IP PORT1 PORT2 ....
Gilles.
