TFTP Error - Path cannot be null
Answered Question
Jun 23rd, 2008
HI
I am trying to save the running config of a 515e PIX to a tftp server. I connect to the PIX using ASDM 5.0
I have set up the TFTP options, interface inside, ip address 172.16.10.9 (my pc), path - /TFTP-Root/ and I have install solarWinds tftp service, on my computer. but I keep getting the following error
ERROR] copy /noconfirm running-config tftp://172.16.10.9/TFTP-Root/test
Cryptochecksum: xxx
%Error writing tftp://172.16.10.9/TFTP-Root/test (Path cannot be null.
Parameter name: path)
Can you tell me what I am doing wrong?
Correct Answer by michael.leblanc about 8 years 7 months ago
I would try:
tftp://172.16.10.9/test
... the TFTP server know's what its own root directory is.
You should only need to specify the host and the destination file name.
Overall Rating: 5 (1 ratings)
Pravin Phadte Mon, 06/23/2008 - 08:52
Its probably the '-'. Try to copy it to your tftp root directory by not putting in a path or just putting in the root dir. I would say just use the root dir for tftp and try again.
Hope this helps,
regards,
Pravin
mohammed_moustafa Tue, 06/24/2008 - 00:23
Hi all,
yes Mic, this is right we don't need to specify the path the tftp solar winds or any other application knows it's path.
B.ragards.
jasoned1969 Tue, 06/24/2008 - 00:54
Thanks guys, when I went to save the config, the root was already in there, so I was adding the file name on to the end. I have just tried saving the config again, but I removed the root first this time, then enter the file name only and it worked
