Remote access using 2811 router
Jun 23rd, 2008
i need someone to please help with materials on the above subject matter.
i need my users to connect to office network via a secure connection,i have a 2811 router facing the internet.
What do i need to configure on this router to enable my home users to connect to the office network.
Your comment is highly appreciated,thanks,cheers.
Paolo Bevilacqua Mon, 06/23/2008 - 08:42
  • Hall of Fame,
    Founding Member
To the users, give the "cisco VPN client" software that is installed on the PC. On the router, configure "Easy VPN" as per documentation. There is a lot of material that you can look on CCO, but the bottom line is the above.
