7906 - speed dials
davieshuw
Hi. im fairly used to using the 7941's with CCME. I've specced up and purchased a load of 7906's for a customer, and they've asked the question about speed dials.
Now I can get my 7941's working fantastically well with the speeddial.xml file.
Is there a way I can make my 7906's look at the same file so they don't just have the standard 4 or 5 speed dial's that you have to set for each phone?
smalkeric
Level 6
Level 6
please verify that each ephone has the "type" configured, then issue a "create cnf" under the telephony-service, and finally reset the phones.
ah ok so once ive done that the contents of my speeddial.xml will show up in place of the 'standard' 5 entry speed dial list on the 7906's?
