3845 IOS upgrade issues
Jun 23rd, 2008
Hi All,
I have a 3845 rtr currently running with IOS: flash:c3845-advsecurityk9-mz.124-3d.bin. Iam trying to upgrade the Image to : c3845-advipservicesk9-mz.124-19b , so the BGP will be supported and I can use this as Internet rtr.
I deleted the existing IOS (delete flash: ) to get space and when I try to upload the new image, the TFTP server is giving error: >> 0: File is too big, try increasing the block size.
Please suggest.
Thank you
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 06/23/2008 - 08:55
Which TFTP server are you using ? You need one that has no files size limits whatsoever.
mvsheik123 Mon, 06/23/2008 - 09:04
Great..thank you. Using Klever Group PumpKIN TFTP... I just checked and the default block size is 2048.
What is recomended size to avoid the message and for successful IOS uploads..?
Thank you
Paolo Bevilacqua Mon, 06/23/2008 - 09:11
Recommend tftpd32 that is free and easy to use. You can also use an ftp otr http server and in fact it's even faster than the udp-based tftp.
As an appreciation to those providing answers, please rate useful posts with the scrollbox below!
