enterprise call center and agent not ready
Jun 23rd, 2008
Enterprise call center 7.x. Customer is complaining this: when a call comes to personal line on the phone and not answer, the agent will kick out and went into not ready status. Is this the limitation of Enterprise call center? i know the other call center product ipcc express does not have this limitation. Can experts clarify this?
Zin.Karzazi Mon, 06/23/2008 - 10:03
The behavior you are describing here is also known as RONA (Ring no answer), the Agent get a Call through the Hotline (CTI-RP) and after the configured RONA time expires the Peripheral gateway will set the Agent to not ready and route the Call to the next Agent (when properly configured).
This should not be the Case when the Agent get a Call to his personal DN!!! as this is a Callmanager configuration and has nothing to do with IPCC.
Are you sure the Customer is referring to personal DN instead of CTI-RP Hotline?
ciscoforum Mon, 06/23/2008 - 10:30
I totally agree with you. That's my thought too. Technically it should not have anything to do with personal line. Customer know agent will be out of the queue if ACD line is not answering since server will have to re-route the call to other available agents. It's the personal line they are claiming. Is there a document or link really document it should not be the case?
Zin.Karzazi Tue, 06/24/2008 - 04:06
Did you check their CCM CDR? you can also use the Query analyzer from the DAW
for instance:
select * from Termination_Call_Detail
AND RingTime= 'xx'
AND CallDisposition='19'
where xx is the RONA time configured on the Config manager-> Agent Desk Setting.
This will help you investigate the exact cause of the probl. HTH.
rbua Tue, 06/24/2008 - 04:12
the agent will move to a not ready status on their CC extension to prevent him/her being reserved for a CC call or being seen available there and counted against the LAA by example.
There is no solution for this since it is the expected behaviour to avoid missed calls.
Matthew Berry Tue, 06/24/2008 - 08:07
Do your agent phones have two lines? If their primary line is set for their personal number, then you can run into this.
When you set an agent to have their agent line as primary, you don't run into this issue.
asomanya Tue, 06/24/2008 - 09:04
I jus tested it, make sure the DNs allocated to IPCC share the same CSS. If the personal DNs are different from the IPCC DNs, calling their personal DN on the same phone device will not trigger the RONA, and thus the Not Ready state.
ciscoforum Tue, 06/24/2008 - 09:13
Thanks. Just double check with you: Did you test on enterprise IPCC or express IPCC? My problem was on enterprise IPCC platform.
