LMS 2.6, RME Baseline Template to Deploy a Banner
Jun 23rd, 2008
I'm working on deploying a banner login to my switches via IOS. I tried it as basic & advanced w/o luck. The job is successful but, there is no banner deployed. Any help would be appreciated.
Paul
Joe Clarke Mon, 06/23/2008 - 09:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What does your template look like, and what version of RME are you using?
czarman Tue, 06/24/2008 - 09:34
RME 4.0.5
+ banner login ^C Banner contents OK^C
Joe Clarke Tue, 06/24/2008 - 09:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try:
+ banner login "Banner contents OK"
This assumes a single line. Multi-line banners require a separate syntax. Each line needs to be separated by \n. For example:
+ banner login "This is a\nmultiline\nbanner"
