06-23-2008 09:55 AM - edited 03-11-2019 06:03 AM
Hello
I'm trying to reset my pix 515E (w/o floppy).
monitor> add 10.10.10.23
address 10.10.10.23
monitor> server 10.10.20.12
server 10.10.20.12
monitor> file np61.bin
file np61.bin
monitor> gateway 10.10.10.1
gateway 10.10.10.1
monitor> ping 10.10.20.12
Sending 5, 100-byte 0xa773 ICMP Echoes to 10.10.20.12, timeout is 4 seconds:
Success rate is 0 percent (0/5)
monitor> tftp
tftp np61.bin@10.10.20.12 via 10.10.10.1
TFTP failed (return:-1 arg:0x0)
Weird thing is that pinging doesn't work and even pinging to itself doesn't even work.
monitor> ping 10.10.10.23
Sending 5, 100-byte 0xa774 ICMP Echoes to 10.10.10.23, timeout is 4 seconds:
The firewall is turned off on the TFTP.
Is there a way to to a hard reset on pix 515E without using TFTP or the floppy?
Solved! Go to Solution.
06-23-2008 12:10 PM
You have to define an interface to work with.
Double check the link it is all there.
e.i 0 would be outside interface
monitor>interface 0
monitor>address 10.10.10.23
etc.. etc..
see if that works.
Rgds
Jorge
06-23-2008 12:10 PM
monitor>interface 0
etc.. etc..
see if that works.
Rgds
Jorge
06-23-2008 12:22 PM
Thanks, that was it!
