Inside Network access DMZ Host
Jun 23rd, 2008
Hi;
I Have a ASA 5510 on my network, which 3 networks (inside, outside, dmz).
When a dmz host access a inside Host, works ok, but when a inside host try access the dmz host, the following message is displayed on LOG:
Deny TCP (no connection) from hid-dmz/25 to hid-iwss/44674 flags SYN ACK on interface dmz
The static nat:
static (dmz,inside) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
static (inside,dmz) 10.40.4.0 10.40.4.0 netmask 255.255.255.0
where:
172.16.1.0/24: DMZ Network
10.40.4.0/24: Inside Network
acomiskey Mon, 06/23/2008 - 10:40
You shouldn't need this...
no static (dmz,inside) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
gilbertojardim Mon, 06/23/2008 - 10:52
even removing this, the problem continues...
all acl's is set to permit traffic...
mohammed_moustafa Tue, 06/24/2008 - 02:02
Hi Dear,
I doubt much that the problem is tha nat translation, error message says no connection this means the TCP SYNC and SYNC/ACK reply are going different pathes so firewall will drop that reply. but to make sure the problem is not in the nat translation use this command:
no nat-control
and remove both the static nat commands
If you can post the configuration of your firewall it will be very helpful.
let me know the results.
B.regards.
