DFM alerts/notifications- delay option?
Jun 23rd, 2008
Is there a way to configure DFM to not email anything unless the event has been active for X polling cycles or X seconds/minutes? This would be for DFM 2.0.11.
Joe Clarke Mon, 06/23/2008 - 10:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, there is no such event intelligence in DFM.
bruceboardman Wed, 06/25/2008 - 05:16
Does this also mean that there is no event suppression based on topology. For example a backbone router goes down, all the events regarding reaching devices on the far side of the down router are suppressed.
jrazvi@enetsolu... Wed, 06/25/2008 - 05:52
I believe you are referring to root cause analysis or event correlation. LMS does not support event correlation.
Jaffer
js88888888 Wed, 06/25/2008 - 09:38
Thanks for the info.
So, does Cisco offer a "comprehensive" monitoring application that includes these types of options? Something more configurable and granular as offered in other non-Cisco apps, if you know what I mean.
Joe Clarke Wed, 06/25/2008 - 09:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
We used to sell a product called Cisco Info Center which was a OEM of Micromuse Netcool. We no longer sell CIC, but Netcool is still available from IBM. It offers a very powerful rule engine for correlating events. The EMC/Smarts InCharge product also offers more configurable options than DFM.
jrazvi@enetsolu... Wed, 06/25/2008 - 11:58
As far as I know, Cisco does not offer anything that meets your requirements. You would need something similar to HP Network Node Manager. Hope this helps...
