Dual ASA 5520's with failover
Jun 23rd, 2008
In a active/standby config, should I use a hardwired cross-connection between them or a separate switch between them. How about in a active/active config? Thanks
trippi Mon, 06/30/2008 - 18:30
Use the failover cable. It was designed for a reason.
nomair_83 Tue, 07/01/2008 - 02:34
  • Bronze, 100 points or more
Dear,
Best way is to use a switch or dedicated vlan.
