DHCP for remote access clients with different subnet from inside interface
Jun 23rd, 2008
I have an ASA, and would like to change from using a local address pool for remote access clients to DHCP. However, the subnet we are using for the pool is on a different subnet as the inside interface of the ASA. Does anyone have this working? Our DHCP expert says that this won't work because of the pool subnet and the interface subnet is different.
1 vote
nomair_83 Tue, 06/24/2008 - 01:11
hi,
I have no idea about microsoft dhcp server but if u use Cisco ACS then u can use built in dhcp server in ACS to assign remote access only and pool can be on different subnet but make sure that your lan has a default route towards ASA inside.
Marwan ALshawi Tue, 06/24/2008 - 04:33
can u send more detail about ur topoligy
is there any router separating the inside asa network from the dhcp network ?
