mohammed_moustafa Tue, 06/24/2008 - 01:51
Hi Dear,
I tried ACL to block P2P programs and it worked, for users traffic going outside it targets certain ports like 80, 443, 25, ... try to only allow these ports targeted by your inside network. If you don't know exactly what ports are targeted you can allow the port range 1 to 1024 providing that your inside network only targets standard applications.
B.regards.
Tauer Drumond Tue, 06/24/2008 - 03:38
thanks for help. I'll test. If I have problem I post again.
Tauer
